Activity Forums Adobe After Effects wiggle question
  • wiggle question
    Posted by Cody Campbell on June 5, 2008 at 9:20 am
    I am attempting to create a distorted film effect in which the picture randomly loses saturation (using the hue/saturation plugin) the problem im having is there is no stopwatch next to the saturation slider so I dont have a way to add a wiggle effect to it… Or do I? Any thoughts?
    _Cody
    “Just because noone understands you does not make you an artist”
    Cody Campbell replied 18 years, 3 months ago 3 Members · 4 Replies
  • Jeremy Fabiano
    June 5, 2008 at 10:32 am
    Deranged thought at 4:30 am…
    Hope it helps, I won’t remember this when I wake up…
    Duplicate your footage, desaturate the bottom copy…
    then play with the opacity of the top (unaffected layer)
    if you mess up the opacity at the right time.. it SHOULD look like it.. im sure theres a better way of doing this.. but i dunno what it is.. too tired 🙁
    -Jeremy
  • Cody Campbell
    June 5, 2008 at 4:37 pm
    DDDuuuhhhh!! Brilliant work around! I’m sure there IS a streamline way to accomplish the effect, but this works just as well. Thanks man!
    _Cody
  • Immanuel Morales
    June 5, 2008 at 8:13 pm
    Cody, there is a simpler way;
    Try using the “Color Balance (HLS)” which has a keyframable Saturation Slider.
    Darqlight on the Rise…
  • Cody Campbell
    June 6, 2008 at 6:47 pm
    There’s the streamline version!! Thanks man
    _Cody
