Activity › Forums › Adobe After Effects Expressions › Wiggle position along a path
  • Pierre-alexis Tremblay
    October 2, 2013 at 3:49 pm
    Just as a precison I want the object to move randomly along a path, not add a simple wiggle expression to a motion path.
    P.A.T.
  • François Leroy
    October 2, 2013 at 4:13 pm
    Hi!
    You can try with this expression:
    François
    t = key(numKeys).time;
    valueAtTime(random(t));
    October 2, 2013 at 4:55 pm
    Thank you François.
    It works but it would be even better if the movement could be smoother, if position along the path could be controlled with a wiggle expression.
    P.A.T.
  • François Leroy
    October 2, 2013 at 5:06 pm
    Then, you can try with this:
    and you can set the frequency, just like a wiggle.
    Cheers,
    François
    frequency = 2;
    seed = Math.floor(time*frequency);
    start = seed/frequency;
    stop = start + (1/frequency);
    seedRandom(seed,true);
    rand1 = random(t);
    seedRandom(seed+1,true);
    rand2 = random(t);
    easing = ease(time,start,stop, rand1, rand2);
    valueAtTime(easing);
  • Dan Ebberts
    October 2, 2013 at 5:10 pm
    Try this:
    freq = 1;
    w = transform.rotation.wiggle(freq,100)-transform.rotation;
    newT = linear(w,-100,100,0,t);
    valueAtTime(newT)
    Dan
    October 2, 2013 at 6:23 pm
    Thanks guys both solutions are great.
    The only other thing to make this totally perfect would be control over random seed.
    Cheers.
    P.A.T.
