Activity Forums Adobe After Effects Expressions Wiggle only positive values two dimensions
  • Wiggle only positive values two dimensions
    Posted by David Cabestany on August 16, 2024 at 5:22 pm
    Can anyone help me make this expression work for two dimensional properties? Currently it only works for one dimension stuff, like rotation, I’d like to use it on position or scale but it’s returning the following error:
    “couldn’t turn result into numeric value”
    w = wiggle(3,.02);
    d = w - value;
    value + Math.abs(d)
    Thanks in advance.
    Brie Clayton replied 2 years ago 4 Members · 5 Replies
  • Yoan Boisjoli
    August 16, 2024 at 5:31 pm
    Can’t test it right now but I think something like this could work:
    w = wiggle(3, .02);
    d = w – value;
    [value[0] + Math.abs(d[0]), value[1] + Math.abs(d[1])]
  • Dan Ebberts
    Depending on how you want it to behave, this would be one way:
    w = wiggle(3,.02);
    d = w - value;
    value + [Math.abs(d[0]),Math.abs(d[1])]
  • David Cabestany
    August 16, 2024 at 5:42 pm
    thanks but unfortunately no dice. it returned this error: “invalid or unexpected token”.
  • David Cabestany
    August 16, 2024 at 5:43 pm
    Dan the man to the rescue, as usual. Thanks a lot.
  • Brie Clayton
    August 16, 2024 at 9:22 pm
    Thank you for solving this, Dan!
