Activity Forums Adobe After Effects Expressions Wiggle in one direction
  • Wiggle in one direction
    Posted by Brian Norris on August 10, 2006 at 3:31 pm
    I’ve used the wiggle expression quite a bit in the past in the form of “wiggle(x,y)” where x is the number of wiggles per second and y is the amount of pixels that my object can move in the horizontal and vertical directions. How can I use the wiggle expressions to only wiggle in the horizontal direction or to wiggle different amounts in the horizontal and vertical direction? Thanks in advance!
    Tom Davis replied 6 years, 4 months ago 4 Members · 3 Replies
  • Steve Roberts
    August 10, 2006 at 3:47 pm
    Search the COW for “wiggle” and “direction”, or “wiggle” and “axis”. This comes up a lot.
  • Mike Clasby
    August 10, 2006 at 4:17 pm
    Wiggle Y Only:
    [value[0],wiggle(1,100)[1]]
    Wiggle X Only:
    [wiggle(5,30)[0],value[1]]
    Wiggle X and Y seperately:
    [wiggle(5,30)[0],wiggle(1,100)[1]]
    You can tie any of the above to sliders, highlight the “1” in the first expression and pickwhip to a slider stopwatch (after you use, Effect>Expression Controls>Slider Control, then name it “Y Frequency”), then the slider controls that number (Frequency 1st number, amplitude 2nd number).
  • Tom Davis
    May 14, 2020 at 8:45 am
    You could try the Jiggle Script from Loop – automatically adds a wiggle in one axis/direction
