Activity Forums Adobe After Effects Expressions Wiggle in one dimension with a floor
  • Wiggle in one dimension with a floor
    Posted by Riccardo Sinti on June 5, 2013 at 4:15 pm
    I’ve seen many posts on this problem but just cant seem to get how to do it or the get results I need form some of the expressions that have been posted.
    Im using this expression on a 3d layer to wiggle only in the Y dimension.
    w = wiggle(6,250);
    [value[0],w[1],value[2]]
    I would like to create a floor for the wiggle so my layer doesn’t go below the floor.
    I understand the clamp expression should be used but I am not sure how to add it to this expression.
    Any help would be appreciated.
    Riccardo Sinti replied 13 years, 3 months ago 3 Members · 6 Replies
  • Dan Ebberts
    June 5, 2013 at 5:12 pm
    Maybe something like this:
    minY = 100;
    w = wiggle(6,250);
    [value[0],Math.max(w[1],minY),value[2]]
    Dan
  • Xavier Gomez
    June 5, 2013 at 5:18 pm
    To clamp below, you can use:
    floor = 0;
    y = Math.max( wiggle(6,250)[1], floor);
    [value[0],y,value[2]]
    Clamping a wiggle doenst work very well because while out of the bounds the final value (y-coordinate) will be constant.
    Provided yours key values always stay above the floor, you can use instead:
    floor = 0;
    maxWiggle = Math.min(250, value[1]-floor);
    w = wiggle(6,maxWiggle);
    Xavier
  • Riccardo Sinti
    June 6, 2013 at 5:09 pm
    Thanks guys for your help but none of those seem to do what I wanted.
    I wound up using this which I cobbled from a the same question I realized I posted many years ago
    w = wiggle(4,200) – value;
    value + [value[0],-Math.abs(w[1])]
    It kept my wiggle in the Y axis from dropping below the layer’s original y start point but when I apply it the layer’s x shifts so I have to relocate along the x axis. I guess that is from adding value + before the [value[0],
    z is not affected I guess because it isn’t mentioned in the array?
    Any idea how to rewrite this so I can leave x and z dimensions alone.
    The next thing I would like to do is be able to add an expression to scale so that when I scale the layer it’s lower edge will always touch the floor.
  • Dan Ebberts
    June 6, 2013 at 6:55 pm
    This should work:
    w = -Math.abs((wiggle(4,200) – value)[1]);
    value + [0,w,0]
    For the scale, couldn’t you just move the Anchor Point to the middle of the bottom edge?
    Dan
  • Dan Ebberts
    June 6, 2013 at 6:59 pm
    I may have misunderstood the second part. So you want to wiggle the layer in the y direction and scale it at the same time so that the bottom edge doesn’t move, is that correct?
  • Riccardo Sinti
    June 7, 2013 at 3:02 pm
    That last expression works great and I actually understand how it is working.
    “you want to wiggle the layer in the y direction and scale it at the same time so that the bottom edge doesn’t move,”
    That’s right, I want the bottom edge to stay at floor level.
    I don’t want to move the anchor point because it rotates around center.
    Thanks for all the help you give this community!
