Activity Forums Adobe After Effects Expressions Wiggle Frame Rate in Posterize Time Effect
  • Wiggle Frame Rate in Posterize Time Effect
    Posted by Jarratt Moody on April 17, 2018 at 10:33 pm
    I need a low frame rate effect with a slight bit of randomness. Something like Posterize time wiggling between 2 and 12 frames per second. Seems simple, but the frame rate parameter doesn’t play nice with the wiggle.
    Jarratt Moody replied 8 years, 4 months ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    April 21, 2018 at 6:04 am
    It would be annoyingly difficult to do with an expression, as you would have to know how many frames a certain value had perpetuated, requiring a for loop to look backwards. I would suggest doing this with hold keyframes on posterize time value.
    Senior Graphic Designer
  • Jarratt Moody
    April 21, 2018 at 10:38 pm
    Thank you, that’s what I ended up choosing to do as well. I think there’s probably some solve with time remapping instead: https://www.motionscript.com/articles/speed-control.html
