Activity Forums Adobe After Effects Expressions Wiggle Flicker expression
  • Wiggle Flicker expression
    Posted by Bryan Woods on January 29, 2013 at 1:18 am
    Trying to create an expression that will trigger when a marker is reached for 12 frames from a marker’s time. I couldn’t find any resource online stating how to make an expression last for a specific duration. Drove me crazy. I tried writing it myself, but I’m not getting anywhere. Any suggestions?
    n = 0;
    if (marker.numKeys > 0){
    n = marker.nearestKey(time).index;
    if (marker.key(n).time > time){
    n--;
    if (n == 0){
    value;
    } else {
    if ((marker.key(n).time) < (marker.key(n).time+12)){
    wiggle(8,100);
    }else{
    value;
    Bryan Woods replied 13 years, 7 months ago 2 Members · 3 Replies
  • Bryan Woods
    January 29, 2013 at 1:32 am
    Hold the phone. I got it.
    n = 0;
    n--;
    if (n == 0){
    value;
    } else {
    if (time < (marker.key(n).time+1)){
    wiggle (5,100);
    }else{
    value;
    However I’m going by timecode, and I’d like to work in frames. I know there’s a timeToFrames, but how do I work that in to this? Do I need to set time converted to frames as a variable? How do I use that with marker.key?
  • Dan Ebberts
    January 29, 2013 at 1:54 am
    I haven’t tested it, but this should work:
    if (timeToFrames(time) < (timeToFrames(marker.key(n).time)+1))
    Dan
  • Bryan Woods
    January 29, 2013 at 2:20 am
    Yup, thats it. Thank you Dan.
    Final flicker code:
    //triggers a flicker at every layer marker lasting 12frames
    n = 0;
    duration = 12; //# of frames from marker
       n--;
    if (n == 0){
     value;
    } else {
    if (timeToFrames(time) < (timeToFrames(marker.key(n).time)+duration)){
    wiggle (10,90);
    }else{
    value;
