Activity Forums Adobe After Effects Expressions Wiggle Expression to Levels?
  • Wiggle Expression to Levels?
    Posted by Jerry Fines on October 2, 2008 at 4:05 pm
    I am trying to ‘wiggle’ only one variable of on a ‘Levels’ effect. The problem is the keyframe doesn’t allow me to add expressions. Specifically I’m trying to affect the ‘Input White’ variable – is there any way to do this? Even if it’s just another effect?
    Dan Ebberts replied 17 years, 11 months ago 2 Members · 1 Reply
  • Dan Ebberts
    October 2, 2008 at 4:55 pm
    Try Levels (Individual Controls). You can add an expression to the Input White under the the RGB twirly. Be careful with the wiggle’s amplitude parameter though. The range on the slider is equivalent to 1.0 in the expression.
    Dan
