Activity Forums Adobe After Effects wiggle expression time limited
  • wiggle expression time limited
    Posted by Jared Eaton on June 7, 2010 at 9:34 pm
    Hi. I added a simple wiggle expression to a camera’s position in AE CS4: wiggle(2,2) My question is what do or how do I add to the expression so that the wiggle only last for 3 seconds? I’m sure this is simple… Thanks in advance for your help.
    Jared
    Jared Eaton replied 16 years, 3 months ago 3 Members · 3 Replies
  • Bob Root
    June 7, 2010 at 10:39 pm
  • Jon Bagge
    June 7, 2010 at 11:23 pm
    Alternatively add an expression control slider, and pick-whip from the wiggle amount to the slider. Then you can keyframe the amount of wiggle.
    This will also allow you to fade up/down the wiggle amount rather than turning it on and off if that’s any use to you. Use hold keyframes to avoid this.
    Jon Bagge
    Editor – London, UK
    Avid – FCP – After Effects
  • Jared Eaton
    June 8, 2010 at 2:04 am
    Thanks so much! This was very helpful!
