Activity › Forums › Adobe After Effects Expressions › Wiggle Expression – get another layer to wiggle one frame after
  • Wiggle Expression – get another layer to wiggle one frame after
    Posted by Kevin Tosi on September 10, 2020 at 10:35 pm
    I’m rigging a character and would like his torso Rotation to wiggle slightly. To do this, I have the expression with Posterize Time and Wiggle:
    //wiggle posterize time
    posterizeTime(f);
    wiggle(f,a);
    In my animation I like to have the head rotate slightly one frame after the torso rotates for a smoother body motion.
    But with this posterize time/ wiggle expression, I can’t seem to figure out how to get the head to wiggle one frame after the torso does. Any thoughts?
    Essentially what that expression above is doing, is giving me a random value every (f) frames.
    I’ve tried just doing (f+1) but it’s not rotating the head one frame after the torso.
    My comp is at 23.976 fps if that helps.
    Thank you in advance for any help!!
    Kevin Tosi replied 5 years, 10 months ago 2 Members · 4 Replies
  • Filip Vandueren
    September 11, 2020 at 9:43 am
    Give the head’s rotation this expression:
    thisComp.layer("torso").transform.rotation.valueAtTime(time - thisComp.frameDuration);
  • Kevin Tosi
    September 11, 2020 at 4:22 pm
    Thanks Filip!
  • Kevin Tosi
    November 6, 2020 at 10:15 pm
    First of all – thanks again for this! Another question – so I’ve added slider controls to this expression so I can keyframe when it goes on and when it doesn’t.
    But once I add the expression – even if my slider controls are set to 0, I can’t rotate the object anymore manually. Do you know if there’s a way to temporarily disable an expression using keyframes?
  • Kevin Tosi
    November 6, 2020 at 10:23 pm
    Never mind I was able to just do an amazing thing called Googling haha
    For anyone looking for something similar – you can use Checkbox Controls. Below is the evolved expression – just add 2 slider controls and a Checkbox control to your layer and add this expression
    control = effect("Checkbox Control")("Checkbox");
    if (control == 1){
    posterizeTime(effect("Slider Control")("Slider"));
    wiggle((effect("Slider Control")("Slider")), effect("Slider Control 2")("Slider"));
    }else{
    value;
