Activity › Forums › Adobe After Effects Expressions › Wiggle expression between 2 values only
  • Wiggle expression between 2 values only
    Posted by Jane Cassidy on December 6, 2010 at 12:33 pm
    I hope I’m not reposting, I just can’t find the answer anywhere. Basically I want to switch a layer on and off randomly.
    In order to do this I’ve added a wiggle expression to the opacity. This works but I need it only to use the values 0 and 100. Is there a way to have it only use these values or do I need to approach this issue differently?
    Thank you.
    Nithish Kumar replied 6 years, 5 months ago 4 Members · 9 Replies
  • 9 Replies
  • Michael Szalapski
    December 6, 2010 at 2:35 pm
    You’ll want the result from your wiggle to be a variable and then use that variable in an if then statement.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Dan Ebberts
    December 6, 2010 at 5:57 pm
    Just set the value to 50 and add an expression like this:
    wiggle(1,50) < 50 ? 0 : 100
    Dan
  • Jane Cassidy
    December 6, 2010 at 11:19 pm
    I got it to work. Thanks a million for your help. Much appreciated.
  • Nithish Kumar
    April 26, 2020 at 3:27 pm
    Can you explain the syntax of this expression ? Cause I’ve seen numbers inside the parenthesis of wiggle expression. Not outside.
  • Dan Ebberts
    April 26, 2020 at 3:35 pm
    It basically says if the wiggled value is less than 50, set the result to 0, otherwise set it to 100.
    ThE ?/: syntax is an example of the JavaScript ternary operator, which is a compact form of if/else.
    Dan
  • Nithish Kumar
    April 27, 2020 at 7:04 am
    Thank you so much, Dan..It was of great help as always……
  • Nithish Kumar
    April 27, 2020 at 7:05 am
    Is there any detailed tutorial for Ternary operator that you can point me to…..?
  • Dan Ebberts
    April 27, 2020 at 7:32 am
    There’s not much to it really, this should cover it:
    https://www.javascripttutorial.net/javascript-ternary-operator/
    Dan
  • Nithish Kumar
    April 28, 2020 at 7:59 am
    Thank you soo much. Will Go thru it…..
