Activity Forums Adobe After Effects Wiggle expression . 1 time in 1second?
  • Wiggle expression . 1 time in 1second?
    Posted by Vugar Ashrafov on October 31, 2015 at 6:31 pm
    Maybe it is very simple and easy subject , but i dont understand this “wiggle” expression all the time. We all know(or only me 😀 ) that for example
    wiggle (1,15) , here “1” shows that wiggle should happen 1 time in one second.but when i try this, it happens 6 times in one second. any idea?
    Kalleheikki Kannisto replied 10 years, 10 months ago 2 Members · 3 Replies
  • Kalleheikki Kannisto
    November 1, 2015 at 5:23 pm
    What property are you applying it to when this happens?
  • Vugar Ashrafov
    November 1, 2015 at 8:39 pm
    i try on rotation . i write wiggle(1,random(-2,2))
    November 3, 2015 at 2:05 pm
    It’s not the first part of the expression that gives you the trouble, you are giving the wiggle a new random number for every frame with the second part of the expression.
    The correct wiggle expression in this case would be
    wiggle (1,2)
    With the value of 2 the wiggle expression itself will vary the results between -2 and 2 in relation to current value.
