Activity Forums Adobe After Effects Expressions wiggle effect on only one axis of movement…
  • wiggle effect on only one axis of movement…
    Posted by Kevin Olmsted on March 26, 2008 at 1:45 pm
    Hello,
    I’m an AE semi-pro but definitely an expressions newbie…
    I’m animating some grass waving in the breeze. It’s a background element so I just applied the corner pin effect to it (a psd) and I want to apply the wiggle expression to the top two corners, but I only want to affect the X axis so the top of the layer only blows side to side. How can I apply wiggle to the layer and only affect one axis?
    If anyone has a better way of achieving this effect I’m open to suggesttions. Thanks very much.
    Kev
    Quest Rogers replied 8 years, 4 months ago 6 Members · 6 Replies
  • Dan Ebberts
    March 26, 2008 at 2:37 pm
  • Kevin Olmsted
    March 26, 2008 at 2:44 pm
    Thanks so much! That link should prove useful for lots of my expressions learning…
    Kev
  • Andy Devries
    March 28, 2008 at 4:46 am
    Very helpful, But I don’t quite have my head wrapped around the 0 and 1 values. I needed to wiggle a 3D object along the x and y axis only so I used [w[0], w[1], value[2]] and it worked great. but I don’t fully understand the logic behind the 0, 1, and 2 values. do you always number array values starting at zero, going up one for each value in the array?
    Thanks.
  • Simon Smith
    September 14, 2012 at 7:23 am
    Thats great – thanks!
  • Tom Davis
    May 1, 2018 at 9:47 am
    For anyone finding this, the Jiggle script may be a useful time-saver especially if you’re not comfortable with expressions.
  • Quest Rogers
    May 2, 2018 at 2:39 pm
    Yes. That’s correct.
