Activity › Forums › Adobe After Effects › wiggle effect not parenting to other file
Posted by David Payne on July 14, 2009 at 11:44 amHi,
I have a photoshop file that I have animated and when I parent a smaller file to it, it moved with the file fine. However when I apply wiggle effect to the keyframed file, the other one does not imitate it.I hope that makes sense and someone could help me?
edit: to make it easier to understand. I have a photo of a house that I zoom in on. I have then duplicated the window frame into a 2nd file but you can see that the seperate window frame does not conform to the same wiggle properties as the background house image.
David Chapman replied 11 years, 4 months ago 4 Members · 9 Replies -
Gary Hazen
July 14, 2009 at 1:13 pmTo clarify, are you using the wiggler or a wiggle expression?
The wiggle expression is sort of like a random number generator. When you duplicate a layer the wiggle pattern for each layer is unique.
The wiggler generates keyframes. If you duplicate a layer that has keyframes applied from the wiggler the movements should match exactly.
David Payne
July 14, 2009 at 1:21 pmhi thanks for the reply.
i used ‘wiggle – position’ from the effects menu.
I have had a look for keyframes to copy and paste to the other layer but it seems it is an expression to generate random numbers like you said.
On the expression line it says:wiggle(effect(“wiggle – position”)(“wiggle speed (wigs/sec)”), effect(“wiggle – position”)(Wiggle Amount (pixels)”))
Todd Kopriva
July 14, 2009 at 2:41 pmYou have used an animation preset (specifically, a behavior animation preset), not an effect.
If you want to generate keyframes that represent motion originally created by an expression, you can use the Convert Expression To Keyframes keyframe assistant.
But I’d probably just stick with parenting the window to the house or precomposing them together and animating the precomposition layer.
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
David Payne
July 16, 2009 at 10:54 amhi, thanks for your reply.
the problem is i have already parented the 2 or 3 window layers to the house, however they wiggle in different ways to the house…Could you explain how to precompose them together and output accordingly? That sounds helpful..
Todd Kopriva
July 16, 2009 at 2:22 pmPrecomposing is a fundamental part of using After Effects. If you’re not familiar with it, then I recommend reading at least the first few sections of the “Nesting, precomposing, and prerendering” part of After Effects Help.
But, basically, you select the layers that you want to precompose together (put into a single nested composition) and then press Ctrl+Shift+C (Windows) or Command+Shift+C (Mac OS). Then you have a single layer (a precomposition layer) that has a composition as its source. You can animate this one layer, and all of the things in the nested composition come along for the ride, just like they were part of one video footage item. You could, therefore, precompose the house and all of its windows together and then wiggle the precomposition to have the whole system wiggle together.
David Payne
July 17, 2009 at 7:51 amthat sounds great, as long as the exported composition doesn’t “flatten” to lose things like photoshop opacity etc then I think this will be the sollution… thanks a lot.
David
David Payne
July 24, 2009 at 8:52 amI have tried this and seem to have the problem I thought might happen.. the composition that I have exported seems ‘flattened’.
Basically I want a layer showing the house the other layer showing the duplicate window frame. I then want to put a layer of say a person in between the other two layers, to create the image that the person is behind the window frame but still slightly visible. I then want to apply a wiggle to all of this to give a realistic camera shake.
Am I right in saying that if I pre-compose as you suggested I can not then ‘split’ the composition into the 2 layers to insert the person between them?
Many thanks
David Payne
August 17, 2009 at 11:52 amok i’ll go at this a different way, is there any way to get a realistic camera shake effect that can be applied to a layer and would then also be applied to layers that are parented to it?
David Chapman
April 23, 2015 at 12:21 pmHi –
I know this is a very old thread, but for those who search for ‘parenting’ and ‘wiggler’ and this pops up, I thought I’d just add a little extra too…
I’ve discovered that if a layer is set to ‘orient towards camera’ and your wiggle expression is on the orientation of a 3D layer, then anything parented to it won’t follow the same orientation.
Once ‘auto-orient’ is switched back to off, the parenting seems to work.
I know this is quite a specific example, but it may help someone!
DC
