Activity › Forums › Adobe After Effects Expressions › Wiggle – Decelerating movement
Posted by Ben Hartley on January 7, 2013 at 4:16 pmCan someone please tell me how to slow down the speed of wiggle so it decelerates and slows to a stop?
If it looks good, look at it.
Ben Hartley replied 13 years, 7 months ago 3 Members · 3 Replies -
Dan Ebberts
January 7, 2013 at 6:21 pm -
Chris Warren
January 7, 2013 at 11:18 pmI do this pretty often for the wiggle effect
If you are using expressions you could control the wiggle with a Slider Control:
Alt/Option click on the stopwatch next to the property you wish to wiggle, for example the Position. When the expression text comes up in the timeline (transform.position) You would retype a wiggle expression like wiggle(10,10,10) Then, add a slider controller to your layer from the Effect window- it’s under expression controls. Then you can pick whip the wiggle to the slider – to do that, highlight the second 10 in the parenthesis and then click the curly pick whip icon from the position property to the slider control stopwatch. Now the Slider control will control the amount of wiggle, and you can keyframe that to speed up and slow down.OR
you could use the Wiggle Effect preset and just keyframe that.
“You are the universe experiencing itself”
ChrisW
http://www.azprovideo.com -
Ben Hartley
January 14, 2013 at 1:10 pmThanks guys both very helpful!
