Activity Forums Adobe After Effects wiggle control
  • wiggle control
    Posted by Dave Hiebert on June 6, 2012 at 7:40 pm
    I have a null object with a light emitter parented to it. I have a wiggle expression on the null for position ( wiggle(.2,450) ) which allows this light emitter to fly around the screen smoothly and randomly which is exactly what I want. There are times when the emitter leaves the screen completely, although only for a second or so at most before returning. Is there some way to create an area that the emitter will stay within?
    I tried to search for this but am not sure how to put it into a few keywords.
    Dave Hiebert replied 14 years, 2 months ago 2 Members · 2 Replies
  • Dan Fredley
    June 6, 2012 at 10:35 pm
    The trick is to separate the wiggle dimensions.
    Assuming that your 3D null’s original position is at the center of the comp and the light’s z depth stays at 0 you can use this:
    x = wiggle(.2, thisComp.width/2)[0];
    y = wiggle(.2, thisComp.height/2)[1];
    z = 0;
    [x,y,z]
    Once you start going back and forth in Z-space it’s a lot harder to limit the movement to comp space. Maybe somebody else has an expression for that.
    You can play around with Z wiggle values to see if it gives you what you want:
    z = wiggle(.2, 450)[2];
    [x,y,z]
  • Dave Hiebert
    June 7, 2012 at 4:23 pm
    very cool….thanks
