Activity › Forums › Sony Cameras › wifi with PMW500
wifi with PMW500
Posted by Robin Probyn on January 14, 2013 at 2:08 pmI buy the wifi adaptor .. plug it in.. then what is the “key” procedure with the 500.. I read its different with the disc 700/800..
Then I can down load ..(something) pilot to my iphone and get a live feed.. is that right or missing something here..
Robin Probyn replied 13 years, 8 months ago 2 Members · 6 Replies -
Ian Cook
January 14, 2013 at 2:22 pmYou need the CBKUPG01 hardware key to activate the wifi.
You can use the XMPilot tool on iOS devices or Sony Experia phones to stream proxy and perform live logging/metadata entry. You can also do this from a laptop using Content Browser (though you need the Advanced Pack option)..
Robin Probyn
January 14, 2013 at 2:30 pmOk thanks.. how does that key actually work then.. couldnt find any info on it on line.. is there an idiots guide .. is it a board that goes inside the camera..? what is it.. ?
Thanks again
Ian Cook
January 14, 2013 at 2:36 pmIt’s a small hardware dongle. It will come with installation instructions.
Robin Probyn
January 14, 2013 at 2:45 pmok thanks.. and that comes with the wifi set.. or is part of it.. only pictures i can find is the wifi transmitter with USB cable..? and what looks like a holder..
thanks re the proxy file ..
Ian Cook
January 14, 2013 at 2:47 pmagain, it’s just a dongle, not much to see. it comes separately and mounts internally. the wifi adaptor mounts on the outside near the handle.
Robin Probyn
January 14, 2013 at 3:01 pmIs the mounting internally a job to be done by Sony tech,s.. ? dont know if I want to venture in there with hammer and chisel ..
