Activity Forums Apple Final Cut Pro Legacy Wierd Thing Happens When Working With Greenscreen
  • Wierd Thing Happens When Working With Greenscreen
    Posted by Joseph Wilkins on July 31, 2006 at 8:29 pm
    I have AE and FCP HD 5.1
    I shoot my greenscreen footage on my HVX200
    I bring it into After Effects and using Keylight, get a beautiful key.
    I export that file as a quicktime file with an alpha channel.
    I bring it into FCP HD and put it in my project and AAARGH! An awful white haze line appears outlining my subject.
    I go back to check AE and put it on the same black backgroound – again – it looks beautiful – no white line around it.
    Back to FCP – Cant get rid of it!!!
    PLEASE someone help
    Joseph
    Jeremy Garchow replied 20 years, 1 month ago 6 Members · 5 Replies
  • Shane Ross
    July 31, 2006 at 8:40 pm
    DVCPRO HD and keylight in AE don’t mix. Trust me…I’ve tried it. The issue is that Keylight doesn’t quite keep the footage “solid.” It is slightly transparent…or SOMETHING…because I got heavy artifacting when I used it. I liked how keylight kept the motion blur, but it just brought out big compression issues. Go to my blog and see what I was dealing with. You will have to go down a bit: http://www.LFHD.net. I posted examples of what I was running into.
    ANWAY…my solution? Shake. This allowed be to create a HOLD OUT MATTE that made the center of the men rather solid, I then used keylight for the edging so that I could get the blur out.
    If you can make a hold out matte in AE, then that is what you need to do. I couldn’t figure it out, and since a buddy of mine is a Shake master and knew, I bought it.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Nick Toth
    July 31, 2006 at 9:01 pm
    Did you try changing the alpha channel interpretation in FCP? Livetype renders always have to be changed to
    “black” from “straight” or they don’t key right. It’s worth a shot
  • Peter Mcauley
    July 31, 2006 at 9:47 pm
    I think Nick is onto something. I had the same problem once. Get info on the the clip and select format. Under alpha you can right click the different alphas.
    Good luck
    Peter McAuley
    Axyz Edit
    Toronto
    G5 dual 2.0
    4 gigs ram
    10.4.3
    FCP 5.04
    QT 7.03
    Kona 2 v1.1.4 with K Box
    4 X 250 gig external F800 Lacie firewire drive
    2 X 23″ Apple cinema display
  • Rick Diamond
    August 1, 2006 at 2:34 pm
    Why not just build the whole comp in AE and forget about exporting with alpha channel?
    Rick
  • Jeremy Garchow
    August 1, 2006 at 4:52 pm
    I would definitely take the advice of switching the alpha from straight to premultiplied (can be done the browser), and I would also double check what your BG color was when rendering out of AE, it should be black. Sometimes AE will pick up a little of the color in the alpha channel and display it in FCP. Changing the alpha type should remedy this problem, though.
    Jeremy
