Activity Forums Adobe Encore DVD wierd subtitle error cs5
  • wierd subtitle error cs5
    Posted by Roar Amundsen on June 14, 2010 at 12:37 pm
    Im authoring a BD disc and I got my subtitles today. I have 5 subtitle tracks. I always check my project after every operation I do to confirm that everything is workin as it should. Everything is fine until I add the last subtitle track (french). Then I suddenly get 5 error messages when I check the project. (one for each subtitle track)
    “Subtitles too close for BD output”
    Can anybody please help me out here? Any idea what this error is? I cant find anything to point me in any direction to solve this problem.
    Im using ecore cs5 currently on a windows ultimate platform.
    Roar Amundsen replied 16 years, 3 months ago 2 Members · 2 Replies
  • Pankaj Gauba
    June 16, 2010 at 6:06 am
    If a gap between two subtitle clips is less than 3-4 frames then this error appears.
    The gap between two subtitle clip should be more than 3-4 frames in blu ray.
  • Roar Amundsen
    June 16, 2010 at 7:40 am
    If somebody else has the problem:
    I found out that if the video is over 1280×720 in resolution the subtitle gap cannot be under 5 frames. (Encores own restriction).
    I was told that this is actually an old restriction in the early days of blu ray specifications. But encore still has that restriction.
