Activity Forums Apple Final Cut Pro Legacy Wierd Render and playback issues
  • Wierd Render and playback issues
    Posted by Jason Rouleau on October 6, 2009 at 6:05 pm
    Hey guys,
    I’ve been trying to solve this one for 2 days now. I’ve imported clips that we’re sent to me via harddrive into FCP. The software reads the footage as HDV 1080i60 (1440×1080). Seems pretty normal, I’ve edited a ton of stuff in that format.
    My Project uses the same settings. However, whenever I’m not playing back any video on my timeline, the preview screen is white. If I press playback, no problem I see the video just fine. If I stop it again, White preview screen…
    At first I figured it was just some stupid glitch and kept on editing my entire project.
    Now my BIG problem is this : If I try to render out my edit with ANY type of effects (filters, transitions, etc) Whatever clip that has an effect applied to it comes out as a white screen in my final output.
    Has anyone experienced this problem before? Any solutions?
    Thank you
    Jason Rouleau replied 16 years, 11 months ago 2 Members · 4 Replies
  • Jason Rouleau
    October 6, 2009 at 6:33 pm
    Thats what I thought at first as well, but why would I be able to playback the clips if that was the case?
    If I preview the clips straight from the Finder, there’s no white screen problem. It only happens in FCP.
    If I put the clips on a Premiere CS4 timeline, I get a yellowbar above the clip. There are no white screens, but I do get alot of video stutter when I try to play the clip.
  • Jason Rouleau
    October 6, 2009 at 10:10 pm
    actually Im using Tiger
  • Dennis Radeke
    October 7, 2009 at 12:51 pm
    Dave is likely right on this one. HDV in FCP land is propietary and so if you did not capture it in FCP, that may be why you’re having problems in FCP.
    assuming it’s a .mov file, you might want to right click on it and look at the inspector properties to see if you can determine a little more about the flavor of HDV you may have.
    As for Premiere Pro, if you’re getting stuttering on the playback, it’s likely that your sequence is a mismatch (maybe it’s XDCAM EX for example) or your system isn’t handling the media very well. If you want, you can put Premiere Pro in a desktop mode and that will allow you to edit any codec that a Mac sees.
    Hope this helps,
    Dennis
  • Jason Rouleau
    October 7, 2009 at 6:10 pm
    Actually I figured out a solution.
    I found out the original clips we’re captured in FCP 5 and I am using FCP 6…
    Anyhow, what I did is I went to EXPORT —-> QUICKTIME MOVIE and exported my sequence as an HDV 1080i60 file.
    For some magical reason it worked. Before I was using the Quicktime Conversion menu to try and export my sequence and thats when I encountered the problem.
    I still haven’t figured out why the problem was occuring, but at least I found a solution.
    Thanks guys for the help, it was really appreciated.
