Activity Forums Adobe Premiere Pro wierd playback
  • wierd playback
    Posted by Riverdance on October 18, 2007 at 1:50 am
    ok i captured an sd clip from my camera. No effects were applied at all but when i play it in the preview window it jumps a frame forward every 30 frames. Now when i play this same clip in wmplayer it’s smooth as can be. Premiere pro 2.0 never had this problem but cs3 does. So i don’t know if there is a setting i’m not seeing for playback or something but it is wierd. Thanks
    Riverdance replied 18 years, 10 months ago 1 Member · 1 Reply
  • Riverdance
    October 18, 2007 at 1:59 am
    Well i just switched computers and second computer didn’t do it. So i’m not sure do you guys know what it could be. Because even encore was jumpy at the same spots with the same clip?
