Activity › Forums › Apple Final Cut Pro Legacy › Wierd light flickering in footage
  • Wierd light flickering in footage
    Posted by Christopher Targia on December 16, 2010 at 8:09 pm
    I have some footage that was shot on a sony XDCAM EX, it was shot in an open convention hall, with poor lighting, however (Im assuming) a mixture of 5600k and 3200k lighting plus interlacing i think, gave this weird lighting flicker to the footage, here is a short video, its heavlily compressed, in the raw footage it actually seems like the differnt color temperatures are scrolling up the screen really fast, if you know what I mean, like a screwed up old CRT screen.
    Flickering Problem
    Anyway, is there anyway I could fix this? some kind of de-interlacing would help? If so what is the best method?
    MacPro Octo Core Intel Xenon 2.8Ghz 10GB DDR2 Ram
    FCP 7.0.3
    -I highly recommend el Gato Turbo264HD-
    Christopher Targia replied 15 years, 9 months ago 3 Members · 7 Replies
  • 7 Replies
  • Christopher Targia
    December 16, 2010 at 9:58 pm
    This was shot in china, however the raw footage is in this codec
    XDCAM EX 1080i60 (35 MB/s VBR)
    I had asked for 1080p30 but this was through intermediaries and language barriers so I kind of expect 25p anyway, and figured I would have to do some compressor transcoding. If you see some of my other threads I have posted recently I had trouble even opening this footage. My boss told me they had shot this on a Cannon, and I found out from the files that it was XDCAM, and XDCAM Transfer and Browser both did not work, I had to use cinemon.mp4 to open the files, in QuickTime they all have horrible interlacing lines, although in final cut they seem fine, except of course for these shots that were in this lighting against a white background.
    FCP 7.0.3
  • Michael Gissing
    December 16, 2010 at 11:53 pm
    China is 50hz mains so the flicker is the wrong frame/shutter for the lights. The camera person should have seen this in their viewfinder and adjusted for a longer shutter to avoid this.
    The answer isn’t just deinterlace. I recall previous threads about such lighting flicker recommend fixing in AE.
    Here’s some more ideas from a google search – https://toolfarm.com/plugins/index.php/Flicker_Removal
    https://www.thefoundry.co.uk/products/furnacecore/features/
    December 17, 2010 at 4:10 pm
    I am trying these filters in both AE and FCP but not having much luck, if it is a shutter problem, why does it not happen for all of the footage? I received about 3 hours of footage, only the footage shot in this particular lighting had this problem.
    FCP 7.0.3
  • Michael Gissing
    December 17, 2010 at 9:13 pm
    [Christopher Targia] “why does it not happen for all of the footage?”
    I wasn’t on the shoot so my guess is that the camera person may have noticed the horrible flicker in the viewfinder and adjusted the camera shutter.
  • Tom Matthies
    December 18, 2010 at 12:09 am
    Depending on the kind of lighting in the area where the shooting took place, the flicker can be better/worse. If the lighting was incandescent (light bulbs) the flicker will be less or not noticeable at all. If the lighting was an arc-type (sodium or mercury) the flicker will be much worse since it will flicker with the frequency of the electrical power in that area. In this case you were shooting at 60 frames/second and the lights were flickering at 50 frames.second.
    Tom
    E=MC2+/-2db
    December 20, 2010 at 2:01 pm
    ok gotcha, 50hz power-source on the lights, with 60fps shutter speeds cause a problem, but now the question is how do I fix it?
    FCP 7.0.3
    December 20, 2010 at 2:02 pm
    it only flickers under certain lighting
    FCP 7.0.3
