Activity › Forums › Apple Final Cut Pro Legacy › Wierd DVCPROHD codec issues
Posted by Brian Buffon on February 4, 2009 at 10:15 amSo-
It’s pretty clear that their are some serious issues working cross-platform with the infamous DVCPROHD codec. That being said, I have a strange issue.
I am trying to avoid this whole problem by simply converting to Animation codec in Quicktime Pro. However any time that I attempt to convert OUT of the original codec, I get seven strange gray boxes placed across the frame. I thought i knew something about codecs, but this is WAYYY beyond me. Any ideas, thanks in advance,
Brian
Greg Booth replied 17 years, 7 months ago 4 Members · 10 Replies -
Walter Biscardi
February 4, 2009 at 12:56 pm[Brian Buffon] “It’s pretty clear that their are some serious issues working cross-platform with the infamous DVCPROHD codec. “
Infamous? I’ve delivered almost 100 HD Network shows using that codec. There’s nothing wrong with DVCPro HD and Final Cut Pro.
Working cross platform will be an issue with any codec. The Animation codec is NOT an editing codec.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Greg Booth
February 4, 2009 at 2:39 pmHi Brian,
It sounds like you’re using a Demo Version of our Calibrated{Q} DVCProHD Decode codec – that’s the Demo watermark pattern that you are describing.
Cheers,
GregCalibrated Software
Walter Biscardi
February 4, 2009 at 3:00 pm[Greg Booth] “It sounds like you’re using a Demo Version of our Calibrated{Q} DVCProHD Decode codec – that’s the Demo watermark pattern that you are describing. “
Well that makes total sense. Thanks for chiming in Greg.
Chris Borjis
February 4, 2009 at 5:09 pm[Brian Buffon] “It’s pretty clear that their are some serious issues working cross-platform with the infamous DVCPROHD codec.”
Blasphemy! 😉
Brian Buffon
February 4, 2009 at 5:14 pmGreg-
Any hints on uninstalling that decoder? I’d love to purchase eventually, but right now I’m just running some tests. Thanks!
Greg Booth
February 4, 2009 at 5:53 pmHi Brian,
Just delete the Calibrated folder found in the /Applications directory and delete the CalibratedDVCProHDCodec.component in the /Library/QuickTime directory and restart.
Cheers,
Greg -
Brian Buffon
February 4, 2009 at 9:56 pmThanks Greg. Really Appreciate it! And for the record, I think that DVCPROHD is a great codec, I just wish it was available for use in compositing via after effects on both platforms, seeing as AE and FCP are pretty closely linked.
Walter Biscardi
February 4, 2009 at 10:49 pm[Brian Buffon] “seeing as AE and FCP are pretty closely linked. “
In reality they’re not. AE is closely linked to Premiere and the CS4 family. FCP is linked to Motion.
AE and FCP work together thanks to the hard work of Wes Plate and he Automatic Duck family.
Many of us who work with FCP also work heavily with AE, but I only work on one platform. If I had to create something for Windows I would render to whatever codec they were using or the Animation codec.
Brian Buffon
February 4, 2009 at 11:32 pmWalter-
Thanks for the advice. I’ll keep that in mind next time I’m compositing with DVCPRO footage.
Greg Booth
February 5, 2009 at 12:47 amHi Brian,
Even another thing to keep in mind is that beginning with CS4 – Premiere Pro CS4 can natively read DVCProHD QuickTime Movies (except for 1080p24, 1080p25, and 1080p30 DVCProHD QT movies) – I have not tried AE CS4 but I’m thinking it’s probably the same (or at least worth testing out)
Cheers,
Greg
