Activity › Forums › Adobe After Effects › wierd crash when draging and adding files to composition?!?
Posted by Metodi Petrov on July 10, 2008 at 9:50 amHi everybody!
I have the following problem:
After Effects works fine for me, until one day it just started to crash when I tried to drag and put any type of file on the composition window!
Ok, the wierd stuff is that when I work an old project or staff it is all right, until I try to put any file from the project window down to the composition!
I tried everything- re install adobe creative suite, remove codecs, update audio and video drivers, even I re install my windows at a point, and then I made a clean instalation of adobe creative suite and it works fine the first 3 days and then suddenly, without any obvious reason – BAAMm! again the same shit-and I am really depressed cause spend days of reading forums, looking for a decision but any ideas how to solve it!
If somebody can help me, thanks in advance!Michael Heid replied 15 years, 10 months ago 5 Members · 12 Replies -
Metodi Petrov
July 10, 2008 at 5:59 pmOf course, excuse my impatience!
I use Matrox Parhelia 256mb video card,
IntelCoreDuo 2ghz and 3.25gb of RAM(Corsair)
with Windows XP 64bit edition,Service pack 2, ACE Mega Pack codecs 6.03(recently temporary removed).
I use Adobe CS3, also with Premiere, Photoshop, Ilustrator, Encore.
Also along with adobe I have installed Edius Broadcast 4.6 and Procoder 3.0.
Recently I used to work with standart avi, mpeg2, mov PAL footage, along with tga, jpeg, psd and more. -
Metodi Petrov
July 10, 2008 at 6:01 pmOf course, excuse my impatience!
Hopefully here is enough information, if something missing, please ask me I will ad!
ThanksMetodi Petrov
Tim Kurka
July 22, 2008 at 8:00 pmI have the same issue I’m trying to solve. I have a different system:
Gigabyte EP35C-DSR3 motherboard
WinXp Pro SP2 32bit
GeForce 8400GS 256mb videocardWhat we have in common is I also have Edius 4.6 and ProCoder 3. Let’s try uninstalling those and see if it helps. It won’t solve the problem, but will narrow it down to where the problem lies.
Metodi Petrov
July 24, 2008 at 2:26 pmDear Dave,
as I already explained, AE crashed on any attempt to drag down to the composition ANY type of file! I don’t use any type of mpeg in my work!
The wierd is that premiere crashed too in the very same way!
I just can’t explain it, cause if I open an old project it’s all working fine until I try to import and drag a new file!Any suggestions?
Cheers
Metodi Petrov
Metodi Petrov
July 24, 2008 at 4:58 pmOK,
I removed edius 4.6 and procoder 3.0 from my sistem, then restart,
then removed AE and Premiere, then restart and then a fresh install both of them and do you know whats happend?!
NOTHING
still the same shit,
crashing!
I’m just pissed of this buggy situation, it’s pain in the ass,
don’t now what to do now, I tried almost everything and any result!
How is it going with you Tim Kurka?
Hope you have more luck then me:)
Cheers -
Tim Kurka
July 24, 2008 at 5:37 pmThere is clearly something going on with Edius 4.6 and CS3. I did the same thing you did with no luck, but then I did this:
I did a Windows XP Pro install on a new drive to make sure everything was clean. I installed AE CS3 and it worked fine. I installed Edius 4.6, then the problem showed up again in AE CS3. I uninstalled Edius 4.6, then manually removed remaining remnants of Edius in the registry. I thought the Canopus Codec could be the issue, but I left that installed to see. AE CS3 worked fine. I installed Edius 4.5 I got from a friend to run a test and CS3 worked!I really wanted Edius 4.6 because plugins are now available, but I will not give up AE CS3. Grass Valley is aware of the situation, but for some reason this is not a problem across the board. Some people are running 4.6 and CS3 fine. I will just go back to 4.0 for now. Another solution if you want is to install another instance of Windows and have Edius on one and Adobe on the other. You just have to reboot every time you want to switch applications.
Jiri Klima
April 1, 2009 at 9:13 amI have very similar problem on both my computers (Lenovo notebook + desktop PC, both running WinXP Pro SP3). Whenever there is Canopus Edius 4.6 installed, none of the Adobe applications work correctly. If I try to drag clips to timeline (in Encore, AfterEffects or Premiere) it crashes down. I tried Adobe CS2 Production Suite, CS3 PS and now CS4 Master Suite and it is the same in all versions.
It worked before with older versions of Canopus Edius (for sure with v.3). Now there is a new Edius v.5, I hope to be able to test it in future.
I can repeat this error any time, if I install Edius, dragging to timeline stops working, when I uninstall and reboot it works again. It is not enough to remove Edius + ProCoder but also Canopus Codec option.
I have seen this problem reported by many users on many forums, so it IS a common problem.
I wonder if Thomson + Adobe will work together to solve this issue?Jiri Klima
Metodi Petrov
April 1, 2009 at 6:22 pmIt would be nice, can you please post the official Adobe Respond in this tread too?
Michael Heid
May 27, 2009 at 1:18 amGetting the same issue running CS4 on a Mac Pro 2 x 3 GHz Quad Core Intel Xeon Mac OS X 10.5.7
Nvidia GeForce 8800GTHappens when dragging from either Finder, or from window to window within AE. And happens with almost all my projects. No Edius stuff that I know of. It could be footage, a still, or even an effect applied to a layer….weird…
