  • Posted by Peter Brusikiewicz on June 11, 2008 at 2:26 pm
    hey so I have footage which was captured in HDV 1080i 60. All the capture settings and the sequence time line were set to this, however, in the browser window, it says that the compressor used is DV/DVCPRO NTSC and the frame size is 720X480. Why? and what are the consequences, if any? the edit goes fine right now, I don’t have to render anything, and it plays well. What gives?
    cheers
    Randy Johnson replied 18 years, 3 months ago 2 Members · 1 Reply
  • Randy Johnson
    June 18, 2008 at 8:18 am
    Your current settings are only effected on new sequences. So if you opened the project then chenged the set settings they will not be implicated directly.
    Or maybe you down converted.
    /randy
