Activity › Forums › Adobe After Effects › Widescreen Resolution
Posted by Chris Mathews on September 5, 2016 at 11:00 pmHello, does anybody know the standard resoltion for 720×400 px video. I need to create animation in the same ascept ratio. Thanks!
Walter Soyka replied 9 years, 11 months ago 3 Members · 2 Replies -
Roei Tzoref
September 6, 2016 at 1:04 amif I am understanding your questions: 720/400 means 1.8 aspect ratio. so it will be a little wide than HD 1280×711 (instead of 720). If I need to upload this file to any of the video publishing services (vimeo, youtube) I would use the HD preset because if you upload a 1280×711 (or 720×400) file, you will get a little black bar anyway at the top and the bottom of your video. read here: https://support.google.com/youtube/answer/6375112
Walter Soyka
September 6, 2016 at 12:47 pmAssuming you mean 720×480 (standard definition NTSC DV), there’s a composition presets you can use (NTSC DV Widescreen). The resolution remains the same, but the pixel aspect ratio changes (pixels are stretched) to make it 16:9.
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn]
