Activity Forums VEGAS Pro Widescreen Redenering W/O AVI format (which is too big)
  • Widescreen Redenering W/O AVI format (which is too big)
    Posted by Anthony Uccello on April 14, 2009 at 4:27 pm
    Hi
    I want to render a widescreen video….however only AVI seems to be compatible so far. Problem is, the video (of 5 minutes) comes out to 1.5GB so its way to big.
    Is there any other format I can reder AVI in and keep the size under 50mb? When I render it as a wmv (which doesn’t seem to support widescreen) its only 23 mb.
    Anthony Uccello replied 17 years, 5 months ago 3 Members · 3 Replies
  • John Rofrano
    April 14, 2009 at 6:45 pm
    What is your target device? If it’s the web, use the Sony AVC or MainConcept AVC type for small mp4 files. If it’s a DVD use the MainConcept MPEG-2 format. Both support widescreen.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Enrique Orozco
    April 16, 2009 at 3:30 am
    …try changing the PAR setting on one custom rendering template to get wide-WMV… I’ve done it before to get perfect widescreen WMVs…
    good luck
    Enrique Orozco R.
    iDEA DigitalVideoStudio
  • Anthony Uccello
    April 16, 2009 at 3:31 am
    Thank you both!
    Both are GREAT!!!!!!!!!!!!!!!!!!!!!!!!!!!
    THANK YOU!
