Activity Forums Adobe Premiere Pro Widescreen problems with 3d rendered guff.
  • Widescreen problems with 3d rendered guff.
    Posted by Roboday on November 12, 2005 at 3:12 pm
    I’m recording footage with my Sony HVR Z1E, its been set to record in 16:9 PAL, Standard Definition.
    When capturing my footage, I use Premiere Pro, I set it to use PAL D1 Widescreen.
    It captures fine, the image looks good, no problems.
    I rendered out using the same preset:
    720x 576
    D1\ DV PAL Widescreen 16:9 [1.422]
    I did set it to “no fileds” because on this particular shot the camera was set to 57p [progressive], not interlaced.
    Im also guessing its anamorphic or something because usually my media player has to adjust its screen to match the correct aspect ratio.
    My next part of the job is to start matchmoving, so im using PFTrack 3 and Matchmover Pro 4, but for my first shot MM4 does the job perfectly.
    So now im exporting it to max, just to do a quick test with a teapot on the ground to make sure there isn’t any slipping.
    What I would normally do is just render a pass of the teapot, then just use premiere to composite the TIF’s back over the top of it.
    This is where my problem is, im not 100% sure what I should be setting the rendered output to, in terms of resolution and aspect ratio.
    If i set the aspect ratio to the same as above, it obviously changes the resolution, so it wont be 720×576, more like 720×540.
    Which is a problem it seems.
    Roboday replied 20 years, 10 months ago 2 Members · 2 Replies
  • Mike Velte
    November 13, 2005 at 10:26 pm
    Dont think that the FX1 has a wide screen/SD mode like some cams…that is what the HDV mode is for. Project and export settings sould be SD normal, not widescreen…actually about 2/3 of your post went over my short head…teapots and tiffs?
  • Roboday
    November 13, 2005 at 11:15 pm
    Yes it does shoot widescreen in all modes if you want it to.
    Anyway, turns out premiere pro cant deal with the footage properly, however after effects can, so from now on i’ll just be compositing even tests with AE.
    So its cool, I figured it out.
