Activity Forums Apple Final Cut Pro Legacy Widescreen NTSC question
  • Widescreen NTSC question
    Posted by Adam Sonnenfeld on January 19, 2009 at 4:53 am
    Hello, quick question here on export settings. I cut a trailer that needs to be delivered to the distributor on digibeta, and I just need some clarification on how to set up the quicktime.
    I’ve been asked for:
    “TRAILER ELEMENTS (preferably 16×9)
    DIGIBETA NTSC
    DIGIBETA PAL
    (Digibeta sound: Stereo Dialogue on Channels 1&2; Stereo M&E on 3&4)”
    I’m not sure whether to export for 720×486 anamorphic or to export at 854×486.
    Thanks again for your help!
    -Adam
    Michael Gissing replied 17 years, 8 months ago 3 Members · 6 Replies
  • Jeremy Garchow
    January 19, 2009 at 5:14 am
    [Adam Sonnenfeld] “720×486 anamorphic”
    That’s it as that’s the pixel aspect ratio that will go to tape.
    Jeremy
  • Michael Gissing
    January 19, 2009 at 5:16 am
    If your sequence is correctly set to NTSC 16:9 then it is 720 x 486 anamorphic. The exported quicktime file should be “use current settings” if it is going to be transferred to digibeta.
  • Michael Gissing
    January 19, 2009 at 5:27 am
    Snap! Jeremy do you sleep?
  • Jeremy Garchow
    January 19, 2009 at 5:31 am
    [Michael Gissing] “Snap! Jeremy do you sleep? “
    🙂 Some days. Yes.
  • Adam Sonnenfeld
    January 19, 2009 at 5:37 am
    Okay. right now my sequence is 1080p Prores at 23.98.
    Can I run the sequence through compressor, or would you recommend that I drop the cut into an NTSC timeline?
  • Michael Gissing
    January 19, 2009 at 6:01 am
    I presume you are making the QT file to take to a facility that does the digi beta for you. I would recommend calling them. If they have a Kona card or other real time hardware down converter, then they may prefer to run the HD file through their down converter to digi beta.
    I experimented with a Sony HDCam as downconverter hardware with dropping a 1080 sequence into an SD timeline and rendering. The render took forever and was softer than the hardware. I haven’t compared Compressor to the sequence render but I am sold on hardware becasue it is quicker and looks better in my experience.
