Activity Forums Apple Final Cut Pro Legacy widescreen matte
  • widescreen matte
    Posted by Ann Lukacs on April 27, 2007 at 12:27 am
    I applied a video filter / matte / widescreen to my entire timeline. Can I remove it?
    Also, if I use this filter as a cheap way to make a 4:3 project look letterbox, will I have any problems when I go to make a DVD?
    Andy Mees replied 19 years, 5 months ago 3 Members · 2 Replies
  • Tom Wolsky
    April 27, 2007 at 12:47 am
    Option double click on the nested sequence and in the filters tab delete the filter.
    Not if you make a basic 4:3 DVD. Your program will have a letterbox on it.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Andy Mees
    April 27, 2007 at 9:57 am
    if you didn’t nest before applying the filter to the whole timeline then you will need to open each clip independently and remove the filter …
    unless you have no other filters applied, in which case you can select all, then choose Edit > Remove Attributes… and in the following window uncheck all boxes except “Filters” and click OK (you might want to make a duplicate of your timeline before such a drastic action tho)
