Activity Forums Apple Final Cut Pro Legacy Widescreen Format Issue
  • Widescreen Format Issue
    Posted by Andrew Hampy on August 11, 2006 at 9:49 pm
    Setup
    Dual Proccesor G4 Tower
    Fincal Cut Pro 5
    Mac OSX 10.4.3
    I have a Sony Handycam DCR-DVD403 camera that I have hooked up to Panasonic AG-DV2500 dv deck through the RCA input in the back of the deck. The mini dvd disk that I am playing through the camera and patching through the deck into Final Cut was recorded in the widescreen 16×9 mode. What are the setting in Final Cut I need to have so the picture does not look stretched. I am ok with it having the black widescreen at the top and bottom but it still looks stretched. The final output for playing this footage will not be a widescreen tv. What do my capture settings and sequence settings need to be so that it does not look streched. Thanks
    Dan O’brien replied 20 years, 1 month ago 2 Members · 2 Replies
  • Dan O’brien
    August 11, 2006 at 10:56 pm
    1) capture the footage
    2) check “anamorphic” in the “clip settings” (although FCP may already have checked it for you)
    3) set up a widescreen dv sequence… it should look correct in your computer monitor, but still squeezed in the ntsc monitor…
    4) do you editing
    5) take your finished widescreen seq and place it into a regular standard dv sequence… it should letterbox it for you at that point. And everything should be dandy…
    [Hampster] “I have a Sony Handycam DCR-DVD403 camera that I have hooked up to Panasonic AG-DV2500 dv deck through the RCA input in the back of the deck. The mini dvd disk that I am playing through the camera and patching through the deck into Final Cut was recorded in the widescreen 16×9 mode. What are the setting in Final Cut I need to have so the picture does not look stretched. I am ok with it having the black widescreen at the top and bottom but it still looks stretched. The final output for playing this footage will not be a widescreen tv. What do my capture settings and sequence settings need to be so that it does not look streched. Thanks”
    Dan
    PrEditors.net
  • Dan O’brien
    August 11, 2006 at 10:57 pm
    Also, for more on this, the FCP manual has a lot of info on “anamorphic” footage. Just do a search for ‘anamorphic’ in fcp help and you should get more info…
    Dan
    PrEditors.net
