Activity › Forums › Adobe Premiere Pro › Widescreen files from AE into Premiere
Posted by Cathy Ralph on June 6, 2007 at 1:13 amHi Gang,
I just got Premiere Pro 2 and I love it – runs solid as a rock!
But I’m a little confused about a project I’m working on in AE that is SD 853 x 480 square pixels (16:9). I want to bring it into Premiere but all the preset choices are 720 x 480 – even for widescreen. I couldn’t find anything in the manual or help files that addressed this. Is there a way to do this or should I resize my AE project to 720 x 480?Thanks in advance for any help you can give!
-CathyCathy Ralph replied 19 years, 2 months ago 4 Members · 11 Replies -
Steven L. gotz
June 6, 2007 at 1:23 am -
Cathy Ralph
June 6, 2007 at 1:37 amThanks Seven,
Changing the pixel aspect ratio may be a problem, as this is an animation and it’s all done in square pixels from PhotoShop. Am I correct in thinking that by changing the pixel aspect ratio in Premiere it will distort the image?
Thanks again for your help!
-Cathy -
Cathy Ralph
June 6, 2007 at 1:39 amThanks Steven,
Changing the pixel aspect ratio may be a problem, as this is an animation and it’s all done in square pixels from PhotoShop. Am I correct in thinking that by changing the pixel aspect ratio in Premiere it will distort the image? Perhaps I should do some more experiments!
-Cathy -
Cathy Ralph
June 6, 2007 at 1:45 amooops! sorry about that! I only meant to post once but I mispelled your name and wanted to correct it.
I just saw that there is a 16:9 preset in Photoshop – so if I create the artwork in that at 720×480 and then bring it into Premiere it might just work!
Thanks again!
Solagratia77
June 6, 2007 at 2:31 amWhen you create new project, Set it to DESKTOP editing mode
then you can make your own custom resolutions.
You don’t have to choose from the presets.I am not sure how you want to incorporate PremierePro into your
pipeline but here is how we do:1) CG/Animations coming from 3D APP rendered in 1280 x 720 @ 24FPS
2) Compositing done in AFX (in 1280 x 720 @ 24FPS )
3) When compositing is done QT MOV is generated (Animation codec with no compression 1280 x 720 @ 24fps / square pixel)
4) Create a new PRJ in PremierePro res:1280×720 pixel ratio:1.0 @ 24FPS
5) Amazingly PremierePro lets me edit these HD clips in realtime with no slowing down what so ever (on a Dual-Dualcore Opteron system with Raptor Drive and 4Gb Ram) even with 14 tracks stereo audio.. I don’t see any slowing down.
6) Then when all the editing is done we render the timeline @ 1280×720/square pixel/24fps (This file becomes our Master)
7) bring this back into After Effects do 3:2 pulldown if it going to NTSC and letterbox it and so on.hope it makes sense…
-J
SolaGratia -
Cathy Ralph
June 6, 2007 at 2:59 amThanks for the info – what I’m doing is much simpler than that – but I’m not getting consistant aspect ratios from 3 programs. At this point I think the problem may be AE and not Premiere, so I posted over at that forum.
I
Brett Howe
June 6, 2007 at 6:38 amYou should be able to use a widescreen preset, and when you import your footage, right click – interpret footage – square pixels!
Thats it!
Good luck
Cathy Ralph
June 6, 2007 at 12:04 pmThanks! Someone on the AE forum found my problem, it was a toggle switch for the composition’s PAR. But what you’ve just told me will also help me bring in footage from ToonBoom later. So thanks again!
-Cathy -
Steven L. gotz
June 7, 2007 at 1:17 pmI am glad you got it worked out. As soon as I saw your problem with After Effects I was going to tell you about the button, but that is the great thing about the COW, there is always someone around to help out.
Steven
