Activity Forums Apple Final Cut Pro Legacy Widescreen export
  • Widescreen export
    Posted by Richard Poth on May 12, 2009 at 6:53 pm
    Hi
    Can anyone help? I have imported video from files which were captured from iMovie, since Final Cut doesn’t seem to be able to capture video from a hard drive camcorder. The shot in widescreen and imported in widescreen. When editing everything appears in the Canvas as widescreen. So far so good! When I try to export using numerous different formats, the final exported video plays back in 4:3 format. Sometimes it will open in widescreen, but will have black either side of the video. I seem to have tried everything and cannot figure out while this is happening. I am only a novice at Final Cut Pro, so am I missing something. Can anyone help??
    Richard
    John Fishback
    replied 17 years, 3 months ago
    3 Members · 2 Replies
  • Eric Johnson
    May 12, 2009 at 9:51 pm
    When in FCP look at your timeline settings (cmnd-0) is your timeline Anamorphic?
    What are your export settings? Timeline settings?
    On the ones that are 4:3, if everything is correct minus the aspect, then you can open in Quicktime, and view the Movie properties (cmnd-J) if you then select the video track you change what the playback dimensions are.
    If you are working in SD, then you can set it to 854×480 and it will look correct.
    But a lot depends on your timeline and export settings.
  • John Fishback
    May 12, 2009 at 10:28 pm
    What kind of file do you want to end up with? What you are seeing is probably squeezed anamorphic. If you want a file that plays widescreen try Export Using Quicktime Conversion. Select Options>Video Settings which with certain formats gives you the choice of 4×3 or 16×9. If that option doesn’t appear there’s also a size button that will let you set the size. In Dimensions choose Custom and enter the size. Hope this helps.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
