Activity Forums Apple Final Cut Pro Legacy widescreen 16:9 help needed
  • widescreen 16:9 help needed
    Posted by Ichiro on November 18, 2006 at 10:38 am
    hello,
    i am new to FCP and found this great place!
    this should be easy:
    3 minute project.
    v1 is tif image (still image) –i can make it whatever size i need to, right now it’s 854×480, but it could big bigger!
    v2 and v3 are very small .mov files that i lifted out of the Brushstroke theme form iDVD 6 (a widescreen theme.v2 and v3 are composited over the tiff and both are well within the borders of the tiff, in fact there simply a paint brush stroke across a small centered part of the image.
    this is all done and works and looks great!
    fyi, i have done this DVDSP (albeit a bit differently) and it it is full widescreen 16:9, SD.
    here’s the issue: it is letter boxed out of FCP. please someone tell me what settings i need to make and if my tiff is incorrect… i just don;t what is causing this.
    v2 and v3 are composited thusly: v2 is multiplied, v3 is travel-luma.
    HELP! i’m going nutz!
    ichiro
    Ben Holmes replied 19 years, 9 months ago 2 Members · 1 Reply
  • Ben Holmes
    November 18, 2006 at 8:39 pm
    You will need to specifiy:
    1) That the sequence is anamorphic – using the check box in the sequence settings
    and if this is correct:
    2) That the item properties for each layer are anamorphic (assuming they actually are) by selecting them and hitting Apple+9 and checking the anamorphic box.
    If the source material is not anamorhic 16:9 you will need to either zoom it to fit (using the motion > scale setting) or change the aspect ratio to fit.
    It sounds like you are trying to put 16:9 elements into a 4:3 sequence – so 1) should fix it, but you will need to start with a blank 16:9 sequence before you place the footage.
    Ben
    Editec Broadcast Editing Ltd
    EVS & FCP specialists for live OB operations. FCP systems just used on Sky Sports coverage of the Ryder Cup – live from the K Club.
    “The Supercar Run” now available for international distribution from http://www.electricsky.com
