Activity › Forums › Apple Final Cut Pro Legacy › widescrean 16×9
widescrean 16×9
Posted by Johnsabbath D’urzo on September 26, 2007 at 4:50 pmwhat does this mean widescrean 16×9??? i’m using final cut pro with aja kona.
what seetings do i use…do i edit in 4×3 or 16×9 or animorphic?????Johnsabbath D’urzo replied 19 years ago 3 Members · 3 Replies -
Chris Poisson
September 26, 2007 at 5:02 pmUh, it means widescreen as opposed to 4×3, but both can be standard def. What are you wanting to do? Using widescreen (anamorphic) is not hard, but you need to know a few things. Suggest you read this:
https://www.kenstone.net/fcp_homepage/understanding_16_9.html
Have a wonderful day.
13
September 27, 2007 at 3:36 am[johnsabbath] “what does this mean widescrean 16×9???”
There are several different forms of wide screen. For example when I watch a wide screen show on my widescreen TV some times it fills the entire screen, and some times it puts black bars on the top and bottom.
16X9 refers to the aspect ratio. 16 units wide by 9 units high.
Johnsabbath D’urzo
September 27, 2007 at 3:18 pmSo how do i know what settings to use??? sometimes designing for braodcast sometimes corporate stuff…how many settings are there?
