Activity › Forums › Apple Final Cut Pro › wide screen: 1920 x 816
  • wide screen: 1920 x 816
    Posted by Adam Chesbrough on April 14, 2013 at 7:12 am
    In FCP7 I was able to create a sequence at 1920 x 816 and then export natively. I can not change the aspect ration in FCPX to an unnative ratio.
    I simply want to end up with an 1920 x 816 mov for upload onto vimeo (who handles it like a champ). Very basic question that I’m sure apple handled in FCPX or compressor. If not then who is working for that company?
    Macbook Pro Retina: 2.6GHZ i7, 16GB RAM 1600MHz DDR3, GT 650M 1GB RAM
    Hackintosh (Sandy Bridge): i5 2500, 16GB 1333MHz DDR3, Nvidia GT640 2GB RAM
    OWC 4TB RAID0 (using esata)
    Tempo SATA Pro ExpressCard/34 (6Gb/s)
    Echo ExpressCard Pro Thunderbolt Adapter
    Paul Figgiani replied 13 years, 5 months ago 4 Members · 5 Replies
  • Paul Figgiani
    April 14, 2013 at 10:53 am
    Is your source footage 1920×1080? If so have a look at my 2.35:1 tool, Cinemascope Toolkit:
    https://vimeo.com/55048656
    -paul.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Brent Cook
    April 14, 2013 at 6:59 pm
    This might help. It’s sort of a work around, but seems to get the job done. Just tried it myself and it works great.
    FCPX_Custom-Resolution-Timelines/video-tutorial
  • Rick Lang
    April 14, 2013 at 7:01 pm
    Paul, does the tool allow a simple change to the modern widescreen aspect ratio of approximately 2.39:1 adopted in 1973? Digitally for 2K that would be 2048×858.
    Rick Lang
    iMac 27” 2.8GHz i7 16GB
  • Adam Chesbrough
    April 14, 2013 at 7:17 pm
    Thanks all around. I downloaded the toolkit, the functionality looks great and is exactly what I am looking for. Far superior to the letterbox filter that is included.
    The workaround is also great for potential projects with strangely oriented screens.
    Thanks again
  • Paul Figgiani
    April 14, 2013 at 8:58 pm
    Rick Lang
    Rick,
    The tool is simply a matting kit that “crops” a 1.78:1 source to 2.35:1. The Compressor Presets handle the cropping upon output …
    -paul.
