Activity Forums VEGAS Pro wide aspect small resolution mp4s
  • wide aspect small resolution mp4s
    Posted by Eric Adler on February 24, 2014 at 11:56 pm
    I am working with a 1920×1080 29.97fps master m2t format source video.
    I wish to create a series of small 160×90 clips to embed on a html5 webpage.
    I attempt to render the video in Vegas 12.0 to mp4 with a resolution of 160×90 but the settings keeps changing the height back to 144. I am using the Mainconcept AVC/AAC codec.
    What I get is a 4:3 resolution video that shows my clip with the 160 width resolution but with black bars on top and bottom. This happens whether I check or not. In the drop down menu I select CUSTOM FRAME SIZE.
    To play my video on all platforms I ultimately want to create ogg and webm versions all with the same resolution of 160×90
    Tyson Onaga replied 12 years, 6 months ago 4 Members · 3 Replies
  • Norman Black
    February 25, 2014 at 12:28 am
    Apparently 144 is a minimum height setup in Mainconcept AVC. I tried Sony AVC and it goes lower but not to 90. 114 was its lower limit.
  • Steve Rhoden
    February 25, 2014 at 5:26 am
    Norman is correct.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • Tyson Onaga
    February 25, 2014 at 9:39 pm
    Have you tried using QuickTime, Custom frame size 160 x 90, then rename the resulting .mov to .mp4?
    MediaInfo reads the file and VLC can play it. Don’t know if it’ll work on your web page tho’.
