Activity › Forums › Sony Cameras › Wide angle lens for Sony EX3
Posted by Mike Harlow on December 30, 2010 at 4:23 pmWas wondering if had any ideas about about 1/2″ wide angle lenses for the Sony EX3 – what about the Fuji 13×3.3 or the Fuji 13×4.6? Thanks.
Max Reid replied 15 years, 8 months ago 4 Members · 5 Replies -
Michael Palmer
December 30, 2010 at 5:08 pmI have the Fujinon 4mm – 32mm made for the EX3 and I love it.
https://www.fujinon.com/Broadcast/Product.aspx?cat=27&id=1206Good Luck
Michael Palmer -
Mike Harlow
December 30, 2010 at 5:16 pmThank you. Have you, or anybody else, heard anything about the Fuji 13×3.3 or the Fuji 13×4.6 for the EX3?
Sandor Bondorowsky
December 30, 2010 at 5:42 pmWe have the Fujinon 3.3. Its an awesome lens! Highly recommend, just pricey. Makes jib guys and stedi ops very happy.
Mike Harlow
December 30, 2010 at 5:45 pmYeah, heard great things about the 3.3, but yes, pricey, according to the company that’s hiring me, but, you get what you pay for.
Thanks, for the info.
Max Reid
January 2, 2011 at 8:39 pmAfter using the Sony 0.8 wide adaptor for six months without ever taking it off, I got the 4-32 WA zoom. It’s a lot wider than the standard lens with the adaptor. Very handy when you work close.
I shot some tests. Blew the images up 100x. They showed a very slight difference. The standard lens is slightly sharper, probably undetectable in regular production.
Also tested the 0.8 adaptor on the standard zoom, and there is difference in sharpness. The adaptor results are still very good, but the WA zoom is better.
If there is a major difference between standard and WA zooms, it seems like the WA, or at least the one I have, has less contrast then the standard. This might make it seem less sharp, but the difference is easily adjusted in post.
The WA zoom is also a front heavy lens, a problem for some. I have had no problems with halos or unusual flare in even the most contrasty situations. I’m happy to have it. It’s on the camera most of the time.
