Activity Forums Canon DSLR Cameras Wide Angle Lens
  • Wide Angle Lens
    Posted by Stephen Smith on June 2, 2014 at 10:17 pm
    I own a Canon T2i and have the stock lens which is 18mm – 55mm. When I was in Italy I wasn’t able to get back far enough to capture everything I wanted. Would purchasing a Wide Angle lens help in that situation or is a 18mm-55mm stock lens as good as it is going to get?
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
    Nick Griffin replied 12 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • George Goodman
    June 3, 2014 at 1:24 pm
    You can buy a lens wider than 18mm, but beware of image distortion.
    “|_ (°_0) _|”
    Sincerely,
    George
    http://www.vimeo.com/georgegoodman
    http://www.linkedin.com/in/georgefranklingoodman
  • Stephen Smith
    June 6, 2014 at 3:47 pm
    Thanks, so a 18mm wide angle lens shows more then a 18mm lens? Also, is there a way to gage how much distortion there will be depending on the lens?
    Stephen Smith
  • George Goodman
    June 6, 2014 at 4:23 pm
    no, 18mm is 18mm – that’s the width. Your lens already covers that width. If you want wider, you’d have to go with some like a 16 or 14mm.
    “|_ (°_0) _|”
    Sincerely,
    George
  • Stephen Smith
    June 6, 2014 at 4:37 pm
    Thanks.
    Stephen Smith
  • Nick Griffin
    June 6, 2014 at 5:44 pm
    Actually the limiting factor is likely to be the T2i. That’s why with still and now video I’ve always stuck with the full frame Canons like the DS1, Mark I and II and now the 5D. I believe that on a sensor the size of the T2i at 18mm you are getting the equivalent of a 28mm lens on a full frame camera, so semi-wide but not wide-wide.
    One of my favorite lenses is Canon’s 16-35mm, f2.8 zoom. I favor wide angle shots for the kind of industrial work I do. The downside to this lens is the cost. Around $1,650 I believe, but Canon has a mail-in rebate of $200 on this and several other items until July.
  • Stephen Smith
    June 6, 2014 at 8:04 pm
    Nick, I never thought about that. There are a bunch of 5D’s here at my work. I can do a side by side test but that makes a lot of sense.
    Stephen Smith
  • Nick Griffin
    June 6, 2014 at 9:16 pm
    If you’re testing the lens that came with the T2i on a 5D be pay careful attention the corners and edges of the image, especially at the widest angle setting. It’s quite possible that the T2i lens casts a narrower circle on the sensor. The fact of the matter is with lenses, like so many other things, you get what you pay for and big glass costs big bucks.
