Activity Forums Adobe After Effects Why won’t my comp loop properly?
  • Why won’t my comp loop properly?
    Posted by Aaron Jacob on April 13, 2021 at 4:44 am
    I’m trying to make a run cycle that loops, followed a youtube tutorial to make the run cycle… it looked fine in the 5 second looping running comp but when I tried to embed that comp in the main scene, it wouldn’t loop properly.
    Please could someone take a v quick look and tell me where I’ve gone wrong? There might be something wrong with one or more of my loop expressions, but I don’t understand why the legs and body look ok while the arms won’t animate properly at all.
    https://www.dropbox.com/s/z37ip7570a2zkx8/R01%20working%20from%20home%20problem.aep?dl=0
    Aaron Jacob replied 5 years, 5 months ago 2 Members · 2 Replies
  • Daniel Poffley
    April 13, 2021 at 7:34 am
    You need to adjust the keyframes in your ‘main scene’ comp.
    In the ‘boy running’ comp, your workarea loops between 05:00 and 05:11.
    You need the keyframes in ‘main scene’ to match.
    Open ‘main scene’. press U to display keyframe. Move the playhead over the first keyframe and change the time (in the left panel) to 05:00. Move the playhead over the second keyframe and change the time (in the left panel) to 05:11.
    Move the keyframes closer together for a faster animation.
  • Aaron Jacob
    April 13, 2021 at 11:58 am
    Thank you so much! Can’t believe I missed something so obvious.
