Activity Forums Adobe Photoshop Why when you merge two layers with LAYER STYLE on, does it change the colour?
  • Why when you merge two layers with LAYER STYLE on, does it change the colour?
    Posted by Daniel Haskett on May 7, 2005 at 9:01 pm
    Hi there
    Basically I have 2 layers, both with Color Overlay set on their Layer Style, but when I merge them down into 1 layer, one of the layers changes colour a bit…dont understand why? Is it merging both color overlays together? If so, how can you get around this?
    Dan
    Lee Brimelow replied 21 years, 4 months ago 3 Members · 2 Replies
  • Jeff Cochran
    May 8, 2005 at 4:07 pm
    I don’t know why, but here’s a couple of things to try.
    1. Create a new, blank layer, link the other two layers to it, (This one has the eye ball, the other two are just linked) then try to merge linked.
    2. Hide all the other layers, and save a copy of the file as a tif or pict file, open that file, copy and paste in place of the other two layers.
    In dealing with layer modes, No 2 will probably be your best bet.
    Jeff Cochran
    https://www.jeffcochrandigitalartist.com/
  • Lee Brimelow
    May 8, 2005 at 4:10 pm
    If you merge two layers together that both have color overlays on them, it will take the style from the bottom layer. If you need to maintain the different colors then you can flatten the layer styles before merging them. To flatten layer styles just merge the layer with an empty layer below it.
    Lee
