Activity › Forums › Adobe After Effects › Why when I create shape from vector layer the fill and stroke isn’t in 1 group ?
  • Why when I create shape from vector layer the fill and stroke isn’t in 1 group ?
    Posted by Supak Suksawat on June 7, 2022 at 2:11 pm
    I have a problem when I create shape from vector layer the fill and stroke isn’t in 1 group, I didn’t know it the problem from after effect or illustrator, when I create shape from vector layer it will be the square path always, It have the way to solve ?
    thank you
    Wilhelm Hagberg replied 4 years, 2 months ago 3 Members · 6 Replies
  • Supak Suksawat
    June 7, 2022 at 2:20 pm
    It always be like this when I create shape from vector layer
  • Chris Voelz
    June 7, 2022 at 2:52 pm
    When making your shape in Illustrator do you have the stroke set to outside aligned? Illustrator to AE strokes will only come in as a stroke if you keep your stroke set to center aligned.
  • Supak Suksawat
    June 7, 2022 at 3:39 pm
    I set it to center
  • Chris Voelz
    June 8, 2022 at 2:28 pm
    Are you trying to bring in your stroke and fill as different layers?
  • Supak Suksawat
    June 9, 2022 at 6:52 am
    in the illustrator, stroke and fill are in the same layers but when import to after effect stroke and fill are in different layers
  • Wilhelm Hagberg
    July 15, 2022 at 10:10 pm
    Are you working with compound shapes in Illustrator? After Effects would interpret e.g. an “O” as 2 shapes: the outer ring including it’s fill, and the ring shape of the center “hole”.
