Activity › Forums › Adobe Premiere Pro › Why was audio was fine in Premiere 6 but glitchy in Premiere Pro?!
  • Why was audio was fine in Premiere 6 but glitchy in Premiere Pro?!
    Posted by Sophie Watson on October 28, 2005 at 10:48 am
    An audio file that sounded totally fine when played in Premier 6 has at least one chronic glitch in it when played or exported from Premier Pro.
    At first i thought it was just a problem with the movie i imported but then i checked back on my older version of Premier 6 and it sounds perfect on there.
    Has anyone else experienced this or similar problem?
    Any advice very gratefully received.
    (i need to export the movie from Premier Pro as I want to use the H.264 codec to make a small file for streaming and this codec doesn’t seem to work on Premier 6.)
    Augie Areyan replied 20 years, 11 months ago 3 Members · 2 Replies
  • Scott
    October 29, 2005 at 5:21 am
    Can you describe the “Glitch”? Stutter, distortion, change of frequency response?
    Scott
  • Augie Areyan
    October 30, 2005 at 5:19 pm
    1st off, thank you for you response.
    The sound is crackle, sparkly, or over-gained (seems exported too loud). But only on Pemeire Pro not Premiere 6 or 6.5.
    I hope there’s an easy fix. If I have to do an extra step, I need to tell my clients it’ll take longer because of this.
    Thank you
    Augie
