Activity Forums Adobe After Effects Why this project take so long to render — Project included
  • Why this project take so long to render — Project included
    Posted by Philippe Gosselin on February 15, 2013 at 4:45 pm
    Hi all,
    First here’s the link for the file
    https://we.tl/XLMIksX0MG
    I found this template online and boy for a less than 10 second animation it takes 1h30 to render, whether I render it in HD or SD.
    Granted I don’t have a top of the line computer, but I can still render HD projects out of Vegas at a brisk pace.
    It is not as though this project uses Hi-def files on top of hi-def files, there is only two precomp file, a psd and a mov which is nothing more than 2 seconds of particles.
    Can any of you open the project and see if there is anything “wrong” with it, something less than optimized perhaps or anything that would allude to the reason why this particular template takes so long to render.
    Darby Edelen replied 13 years, 7 months ago 4 Members · 5 Replies
  • Paul Roper
    February 15, 2013 at 4:55 pm
    I think your problem is that it’s just a hideously over-nested-comp project. There are comps in comps in comps – a ridiculously huge amount of layers to achieve something that just doesn’t warrant it.
    Without remaking the project from scratch, I think you’re just going to have to put up with long render times. It would probably take longer to remake it than to wait for the render. Make sure you do a super-low res. render to check everything works before setting off your big render.
    – Paul
  • Vishesh Arora
    February 15, 2013 at 5:05 pm
    Paul
    The project is very complex. There are several effects, many Precomps and expression and nesting of compositions which is making the render slow.
    You can Pre-Render certain elements specially Flares or use Proxies which will reduce the time needed to calculate them again and again.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Philippe Gosselin
    February 15, 2013 at 5:12 pm
    Actually it was faster to make a movie out of the RAM preview than to render the whole thing!
    I found the template on a free website, I guess I wanted to have my cake and eat it too but alas 🙁
    Thanks Paul & Vishesh
  • Paul Roper
    February 15, 2013 at 5:36 pm
    The RAM preview may have been faster depending on your preview settings – maybe it was set on Fast Draft or Half Resolution, in which case the resulting movie would not look as glorious as the full render.
    But there are so many effects and layers on that project, it will always be slow to render on even the fastest machines.
    – Paul
  • Darby Edelen
    February 16, 2013 at 6:57 am
    [Paul Roper] “But there are so many effects and layers on that project, it will always be slow to render on even the fastest machines.”
    The primary reason this project renders slowly is the use of CC Radial Blur at 100 Quality. Replace all of these with CC Radial Fast Blur and you should see a 2-4x speed increase.
    For future reference I highly recommend enabling “Show Rendering Progress in Info Panel and Flowchart” in Preferences > Display and looking at your info panel as you wait for a frame to render. This is a good way to diagnose slow effects so that you can try to find a replacement or settings that will improve render speeds.
    Darby Edelen
