Activity › Forums › VEGAS Pro › Why there is no Cancel in Event Pan/Crop dialog
  • Why there is no Cancel in Event Pan/Crop dialog
    Posted by Chuck Lao on February 6, 2008 at 11:56 am
    Sorry for a newbie question. Sometimes I try things in the Event Pan/Crop dialog window but wish not to carry changes to the timeline. But there seems to be no way to cancel the change other than undo after the fact. Thanks in advance for any help.
    Chuck Lao replied 18 years, 7 months ago 2 Members · 4 Replies
  • Edward Troxel
    February 6, 2008 at 7:57 pm
    I guess you could delete the keyframe if you wanted to eliminate ALL changes at that time. Or right-click the keyframe and choose “restore” which will put it back to default settings.
    Hard to say exactly without really knowing what you’re doing.
    Edward Troxel
    JETDV Scripts
  • Chuck Lao
    February 6, 2008 at 8:17 pm
    Thanks Edward. Once again, I need your help. What I means is most in applications I have options to save changes or exit without saving; however, all most all Vegas dialog windows do not have Save or Cancel. For example, in the Vegas Event Pan/Crop dialog window, what if I try something and decided not to apply changes to timeline. I just want to exit the Event Pan/Crop dialog window. Right now, I only see a [x] button on the top right corner which always apply changes to the timeline upon exit. Is this how Vegas works or am I missing something.
  • Edward Troxel
    February 7, 2008 at 3:26 am
    If you don’t want the changes you just made, you must use “UNDO”. In fact, you may have to undo multiple times if you made several changes in the window. There’s also a drop-down arrow beside the undo button which will let you undo several things at once.
    Edward Troxel
    JETDV Scripts
  • Chuck Lao
    February 7, 2008 at 5:06 pm
    Thanks for the confirmation. I don’t understand why Vegas doesn’t put a [y] button next to [x] button on all dialog boxes. It is much easier to click cancel than multiple Undos; more importantly, it is a mental model shift for me as this concept goes against all other window’s applications. I guess I have to live with this quirk.
