Activity Forums VEGAS Pro why the lower cpu usage?
  • why the lower cpu usage?
    Posted by Laszlo Kovacs on October 6, 2005 at 4:54 am
    I looked at task manager the first time since
    I began to use my new machine.
    (Asus P4P800E-deluxe, P4 3GHz, 1 GB Dual DDR (2*512M)).
    While rendering, cpu usage is between 53..61%.
    Why not 100%?
    Yes, it’s about HT, and Vegas processor affinity
    is checked to both processor, and it really uses
    both, but not at 100%.
    That means, vegas does not use the whole potential
    of my machine.
    Is this normal, or do I have to tweak something?
    TIA,
    By(t)e
    Laca
    Ted Snow replied 20 years, 11 months ago 4 Members · 8 Replies
  • 8 Replies
  • Gary Kleiner
    October 6, 2005 at 6:05 am
    It IS normal for Vegas 5, but Vegas 6 should be right up there in the 90s.
    Gary
  • Laszlo Kovacs
    October 6, 2005 at 6:41 am
    Sure, I forgot to mention it’s about Vegas 5.
    Thanks Gary!
    By(t)e
    Laca
  • Rick Wise
    October 6, 2005 at 9:50 pm
    Gary,
    Does that mean Vegas 6 will render faster than 5 on the same computer?
    Rick
    Rick Wise
    director of photography
    Oakland, CA
    http://www.RickWiseDP.com
    email: Rick@RickWiseDP.com
  • Gary Kleiner
    October 6, 2005 at 10:22 pm
    Without tricking Vegas 5 into using more of the CPU (two projects rendering at once or newtork render with two nodes), yes, Vegas 6 makes better use of the availabloe CPU power and renders faster.
    Gary
  • Rick Wise
    October 7, 2005 at 12:12 am
    So how can one trick an older computer to render faster using Vegas 5?
    Rick Wise
    Oakland, CA
  • Laszlo Kovacs
    October 7, 2005 at 4:57 am
    An older computer has not enough power to
    render faster.
    So there’s no need to trick.
    By(t)e
    Laca
  • Ted Snow
    October 7, 2005 at 5:21 am
    [Laszlo Kovacs] “An older computer has not enough power to
    render faster.
    So there’s no need to trick.”
    Having V5 doesn’t necessarily mean you have an older computer…just an “older” version 🙂
  • Ted Snow
    October 7, 2005 at 5:26 am
    oops…you were referring to “his” computer… 🙂
