Why the firts picture of the clip is not shown ?
Posted by Timothée Ferreol on March 21, 2015 at 6:29 pmThis is one of the most annoyinthing g I get on SVP.
Basically, if I put my cursor at the begining of a clip, it is not the very first image of that clip that will be shown, but the one just before.On the picture you can see I intended to place my cursor at the begining of the red color but the previsualisation tab show me the white color…
This situation also happens with I look at the previsualisation of the first keyframe of a clip.Is there a way to fix that ?
John Rofrano replied 11 years, 5 months ago 4 Members · 12 Replies -
Aleksey Tarasov
March 21, 2015 at 7:18 pmMake sure that Quantize to Frames option is ON (under Options menu).
John Rofrano
March 22, 2015 at 12:11 pm[Timothée Ferreol] “Basically, if I put my cursor at the begining of a clip, it is not the very first image of that clip that will be shown, but the one just before. “
Your playhead is NOT at the beginning of the clip. Zoom in and see for yourself:
Try using the ‘[‘ and ‘]‘ keys to navigate to the event edges. Note that pressing ‘]’ once will still show white because you are on the last frame of the white clip. Press ‘]’ again will show red because you’re on the first frame of the red clip. So each press of ‘]’ or ‘[‘ navigates to the first or last frame of the event (i.e., you have to press it twice to skip to the first frame of each clip).
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Timothée Ferreol
March 22, 2015 at 2:02 pm@Phil Peacock
Yeah snapping is on.Well I noticed my playhead is not exactly at the begining of the clip on this picture but it does the same even if i perfectly placed it at the beginning of the second clip.
See :
You’ll notice that my cursor is on the very first keyframe of the white clip and that it shows me red.
Aleksey Tarasov
March 22, 2015 at 2:33 pmYour events do not start at frame boundaries – turn on Quantize to Frames and move them to the nearest frame boundary.
John Rofrano
March 22, 2015 at 4:48 pmWhat is your Timeline Ruler set to? I see that your project is 23.976. Is the Timeline Ruler set to SMPTE Film Sync IVTC (23.976 fps Video)?
~jr
Timothée Ferreol
March 22, 2015 at 5:59 pmNo, It was not, it was on “Time & Frames”, I changed it to ” SMPTE Film Sync IVTC (23.976 fps Video)”. But I still get one frame before on the previsualisation tab when I hit at the beginning of a clip
John Rofrano
March 22, 2015 at 6:40 pmTry moving the clips with the new timeline ruler setting and see if they change position to snap to line up.
~jr
