Why the black edge on top and bottom?
I am trying to get the highest quality video from FCP to FLV to fit the flash player that the web designer told me. Changing the framing of the player is out of the question because I have tried that route many times and they won’t.
The FLV player is set to 643×362 which is a 16×9 frame, ratio 1.78. However, my source material is all over the place, so I have to conform everything. Some footage is animation that I made in a 16×9 frame, some is 16×9 HD footage, and other is letterbox SD fotage. I’ve put links below with each case. I’ve been at it for the whole weekend and can’t come with a solution. They really want the video to fill in the whole flash player and told me to just zoom in on the video to get rid of the black on the tops, but I feel that is changing the pixels aspect ratio and the image looks strange.
So got some links for you to take quick peaks:
Case#1:
– Video/Animation that I did in Motion at 960×720,pixel aspect ration of 1.33, Field Order Lower First (even) @ 29.97fps
– exported the QT and did tried two things, but the one that looked the best has this workflow: import the animation clip into FCP, then export out using QT Conversion to the player setting size. After that put that clip into Adobe Media Encoder. Text looks pretty sharp, some video is eh…But fills up the whole player.See here:
https://www.episcopalchurch.org/JWPlayerDemo/flow/But it is all the other stuff I am having problems with.
Case#2:
This footage is HD, so it is already natively 16×9. Shot on that Sony, cut with the other animation that I had created. Exported using the the same QT Conversion and run through media encoder. End result, black along the edges.See here:
https://www.episcopalchurch.org/JWPlayerDemo/flow/Katherine2.htmlSettings I put: Dimensions 643×362, preserve aspect ratio using letterbox if necessary because “crop” which is no good with the lower thirds and the FitWithin, just messes up the pixels period.
When I export the native QT into compressor, I set up a droplet to the specs, but doesn’t looks so sharp.
See Here:
https://www.episcopalchurch.org/JWPlayerDemo/flow/Katherine.htmlCase#3
Now we have to deal with the SD footage with the letterbox. Same issue, but black edges a bit more than the HD footage.See here:
https://www.episcopalchurch.org/JWPlayerDemo/flow/JonBruno.htmlAm I missing something?
Thanks to whoever can answer this.
Also I use Adobe Media Encoder on my Mac Pro Tower using Leopard.
