Activity › Forums › VEGAS Pro › Why So Slow?
  • Why So Slow?
    Posted by Dan Sherman on October 30, 2005 at 2:42 pm
    Vegas is taking forever to open, sometimes several minutes.
    Have reistalled Vegas, refreshed windows diabled media manager scanned for viruses, cut back virtual memory—-done everything I know possible. All hard drives included the system drive have ample space.
    Still takes forever to open.
    What do you suspect.
    Open to any thoughts or suggestions.
    Yes I have Vegas 6.0c with a Gig of RAM and a pretty face machine
    Edward Troxel replied 20 years, 11 months ago 6 Members · 6 Replies
  • Christopher Wright
    October 30, 2005 at 5:48 pm
    How can I get a “pretty face machine” Microsoft’s answer to cutesy Apple?? ;>)
  • Edward Troxel
    October 30, 2005 at 6:51 pm
    My first suspicion would be that it’s looking for some device that isn’t there and it finally times out when the device is not found. Maybe something like a scanner?
    Edward Troxel
    JETDV Scripts
  • Chris Young
    October 31, 2005 at 2:51 pm
    A long shot here but do you have Canopus Procoder on your machine? If you have check that under ‘Queue Manager’, Tools that ‘Start Kernel with Windows’ is turned ‘off’. There were a few reports around that this was dramatically slowing down some PC’s on start up. I can confirm this as I suffered the same problem. Back to normal since turning it off. It’s also a memory hog and doesn’t need to be started with the Windows bootup. It will start when required if you use the Queue Manager.
    Chris Young
    CYV Productions
    Sydney
  • Doug Graham
    October 31, 2005 at 9:12 pm
    I don’t think it’s those.
    I experience the same thing…and it’s not a slow system bootup, it’s a slow start of the Vegas program itself. 6.0 does seem to take a long time to get going, compared to previous versions.
    Regards,
    Doug Graham
  • Wade Harrington
    October 31, 2005 at 10:41 pm
    If you don’t use the media manager Un-install it, and it will open much faster. If you use media manager deal with it for now??
  • Edward Troxel
    November 1, 2005 at 1:43 am
    You don’t have to actually uninstall it. You can simply turn it off in the preferences. Once turned off, Vegas 6 will load at roughly the same speed that Vegas 5 loaded.
    Edward Troxel
    JETDV Scripts
