Activity › Forums › VEGAS Pro › Why separate video/audio render?
  • Why separate video/audio render?
    Posted by Andy Pauquette on December 6, 2010 at 11:20 pm
    First, I am very glad I found this forum, and I’ve learned a lot from lurking for the last few weeks. Thanks to all of the knowledgeable people who are willing to share.
    I’ve been (clumsily) using Vegas since v6, mostly for wedding videos. I’ve always rendered my finished projects with the audio (I selected the DVD Architect template, but checked the “include audio stream” box) and then dropped the rendered file(s) into a DVD Architect workspace to make a simple menu-driven DVD. It always seems to work fine, but I’m getting the impression I’m not supposed to do things this way.
    What is the advantage of rendering video and audio separately for DVD Architect? I’m not using multiple languages, nor am I using 5.1 audio, just stereo.
    And a possibly related question: what is the maximum length of video that I can fit on a DVD, properly rendered?
    Thanks in advance.
    Andy
    Dave Haynie replied 15 years, 10 months ago 3 Members · 3 Replies
  • John Rofrano
    December 7, 2010 at 1:21 am
    [Andy Pauquette] “What is the advantage of rendering video and audio separately for DVD Architect? I’m not using multiple languages, nor am I using 5.1 audio, just stereo.”
    The advantage is not re-encoding the audio twice. The audio from your camera is probably uncompressed PCM which is very high quality. Then you render it to highly compressed MPEG2 with the DVD Architect template which is much lower quality. Then DVD Architect renders the MPEG2 audio again to Digital Dolby AC3 and it looses even more quality. It is far better to render the final Digital Dolby AC-3 file from the uncompressed PCM source than from a 2nd-hand MPEG2 file. If you are in a PAL country, then MPEG2 audio is allowed on DVD’s but for NTSC countries MPEG2 audio is not part of the spec.
    [Andy Pauquette] “what is the maximum length of video that I can fit on a DVD, properly rendered?”
    I’m not sure what you mean by properly rendered. If you mean without lowering the default quality, then you’ll get about 1 hr 20 minutes. To get more you can reduce the bit-rate which reduces the quality but also reduces the file size. How low you go is up to you. I would not go lower than you can visibly see the difference (which is somewhere around 4Mbps from the default 6Mbps average)
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Andy Pauquette
    December 7, 2010 at 2:56 am
    Thank you, John!
  • Dave Haynie
    December 7, 2010 at 6:51 am
    It’s a little bit tradition, and a little bit format-related.
    Back in the dark ages, DVD Authoring tools only accepted completely finished assets. They did a little basic MPEG-2 rendering for menus, but didn’t convert you video. DVD was a new format, and nothing you had in your video editor or encoder produced something in DVD format. Apps took MPEG-2 elemental streams, WAV files, AC-3 files, or MPEG Layer 2 audio files… they did the DVD multiplexing, etc. from those simpler formats — which also got the DVD authoring apps done quicker.
    This is still a tradition with Vegas and DVDA. The main reason DVDA accepts a DVD-format MPEG-2 PS rather than elemental stream are chapter marks and other imports… an elemental stream is just the MPEG-2. There is no official standard for AC-3 or uncompressed in an MPEG-2 file (technically, the .VOB file format on DVD is an extension of the MPEG-2 format that supports these, but this not part of the MPEG-2 standard). You COULD technically produce an MPEG-2 stream with MPEG Layer 2 audio an author a correct DVD… for Europe. On Region 1 DVDs, MPEG Layer 2 is a secondary format (optional playback on player), not a primary format (mandatory playback on player).
    As for how long your video can be … 4,700,000 bytes. That’s the real answer. You can use a bitrate calculator to figure out how much compression you need, based on your audio type and video length. Then you compress it, using the best quality 2-pass encoding from Vegas (don’t leave it to DVDA to compress), and then burn a preview disc, and determine if you’re happy with the quality.
    I made a small film back in 1994 which went to DVD some years later (using one of the aforementioned early DVD authoring tools, Pinnacle Impression, formerly Minerva Impression, possibly the most bug ridden piece of drek I ever managed to coax useful work from). The main film is 2 hours long, there are some 30+ minutes of outtakes and other special features (a photo gallery, music videos, etc). It looks good because, frankly, the video was crap. I shot it 1994 in Video8, not even Hi8, and the DVD was compiled from both the original tapes and an SVHS master. So a little more compression there didn’t greatly impact the video, because the whole video process was low-pass filtered. I’m not suggesting an HD downconversion will look acceptable a 3 hours or more on a DVD, but it’s up to you.
    -Dave
